60mph+ vibration... DESPERATE!! - MustangForums.com
Old 06-09-2009, 03:34 PM   #1
desdain
Default 60mph+ vibration... DESPERATE!!
Okay, here is my setup and problem. I have a 1966 Mustang fastback with a 347 stroker, C4 transmission, stock driveshaft, 8 inch rear axle with posi, original leafsprings with slide-o-link traction bars, and Wilwood disc brakes.
When driving at speeds of 60mph or higher, there is a severe cyclical reverberating hum that rattles and vibrates the entire car. It's cycles in and out about once a second, faster at higher speeds. I have put the car in neutral while rolling downhill and the hum is still there, but it seems to become more constant rather than cyclical then. This leads me to believe it's a problem with the drivesystem.
Here is what I have done so far:
- Set the angle between the engine and rear axle by adding wedges between the axle and leafsprings (they were off by 4 degrees, but now they are exactly parallel)
- Replaced the rear bushing in the transmission (the slip yolk had some play in it, but now there is very little play)
- Straightened and milled the axle shafts (when the car was on stands and wheels rolling, there was severe wobbling in the wheels. This wobble is now gone).
- Reduced driveshaft wobble (there was a 1.5mm wobble in the driveshaft caused by bad rear u-joint mounting holes, but this has now been reduced to 50 microns by positioning the u-joint correctly with some tack welds. Yeah, I know this is a no no, but it was our only option. The driveshaft itself is quite straight)
Things I have not done yet:
- Balanced the rear wheels
- Replaced the transmission mounting bracket
- Tried a different driveshaft
- Removed the traction bars
- Two sticks of dynamite up the tailpipes ;-)
I'm getting really frustrated by this as we keep fixing all these different issues, but nothing seems to give any results. Now I'm hoping that someone here can point me in a direction that might give me some results. I have searched the forum for similar posts, but none of the ones I have found have helped so far.
Thanks a lot!
desdain is offline   Reply With Quote
Old 06-09-2009, 04:14 PM   #2
Randys66gt
Randys66gt's Avatar
Run your hand along the side of the driveshaft. Remember, think of it as a straw. Any dents in it will cause an out of balance condition. Had a friend the hit a box in the road and it dented the shaft just enough to get a vib around 50 mph. Good luck.
Randys66gt is offline   Reply With Quote
Old 06-09-2009, 04:54 PM   #3
Oxnard Montalvo
Boner Exspurt
Oxnard Montalvo's Avatar
Spin balance the wheels. You may have an out of round tire or two.
Oxnard Montalvo is offline   Reply With Quote
Old 06-09-2009, 07:13 PM   #4
jcoby
Quote:
Did you jump the car off a ramp trying to play Dukes of Hazzard?
If it was dropped hard enough to bend the axles, the bearings might have dimples in the races. that could cause your symptoms. the axle housing itself might even be bent.
jcoby is offline   Reply With Quote
Old 06-09-2009, 09:19 PM   #5
dodgestang
dodgestang's Avatar
You need to get the driveshaft balanced.
dodgestang is offline   Reply With Quote
Old 06-09-2009, 09:21 PM   #6
Mustangdemon67
Mustangdemon67's Avatar
u joints?
Mustangdemon67 is offline   Reply With Quote
Old 06-10-2009, 01:15 AM   #7
desdain
Well, I did hit a really big hole in the road in a construction zone last year. They had cut a 2 ft section out of the road and no markings. Didn't see it until I was in it basically and it really hit my rear end hard. I'm suspecting that's what messed up my axle shafts, but I can't be sure.
Old 06-10-2009, 03:56 AM   #8
desdain
Quote:
Originally Posted by Mustangdemon67 View Post
u joints?
Front u-joint is new and rear u-joint checked to be okay. This is the one we tack welded to be able to center the shaft.
Old 06-10-2009, 08:18 AM   #9
boeing747arowair
maybe your axles are shot after that pot hole hit
boeing747arowair is offline   Reply With Quote
Old 06-10-2009, 08:39 AM   #10
urban_cowboy
urban_cowboy's Avatar
The first most common thing that causes vibration at 60-70mph is tire balancing. Have your tires road balanced if possible or at least spin balanced. After they are known to be good, think driveshaft balance, replace axle bearings, check for proper driveshaft slip on the tranny yoke, check for proper tranny yoke fitment (too much play will cause vibration...ask Gun Jam), check engine and tranny mounts, and check exhaust mounts (they too can cause harmonic vibrations).
urban_cowboy is offline   Reply With Quote
Shift Linkage Broke, Could Really Use Some Help CMcNam 4.6L V8 Technical Discussions 15 12-06-2015 02:28 PM
Dealership wants to "BUY BACK" my car? Geno 2005-2014 Mustangs 20 03-07-2006 09:40 PM
no where to turn (serious gf trouble) HamMach1 Off Topic 75 02-04-2006 11:04 AM
Need Help: About to take car for service GGIII GT S197 General Discussion 19 12-08-2005 01:27 PM
IN DESPERATE HELP OF EXHAUST SYSTEM!!!! GrayGhost01GT Pipes, Boost & Juice 6 07-17-2004 01:36 AM
03, 1967, 50mph, 60, axle, c4, driveshaft, ford, mustang, shaft, t5, trans, transmission, vibration, wc, wobble
