TKO in my '65
I think this is the route I am going to try. Do you remember what you used for a bellhousing and clutch? Is the 1" spacer behind the bellhousing standard or just with the stock bellhousing? I have a lakewood blowproof bellhousing now. How did that 408 fit?
Sorry for all the questions but thanks for all your help!
Cody
Cody
I know the adapters are available for your Lakewood bell because I was looking that direction until I found the TKO speciffic bell.
I think the 408 fit great asside from a little header dimpling... no problems at all with the Lakewood sheild.
Ya I understand that being a problem. Mines raised a little bit in the back so that should be to my advantage. Im going to try and make this work with out cutting the tunnel but I will if i have to.
In my 67 I used a Quitime SFI bellhousing, and the Modern Driveline crossmember, which drops the trans tail down. I also had to use engine drop mounts to keep the driveline angle correct, and slide everything over so the trans didn't contact the tunnel, it's pretty tight and some beating out of the tunnel would have helped it fit better. It's supposedly even tighter in a 65/66, but it can be done.
musnicki
09-23-2015 07:11 AM
cfmperf
05-20-2005 07:07 PM
