There is no fan shroud in place. Fan shroud is non-existant... Or just invisible... but not there.
Jus saying...If it was the motor mounts, even one, you would see the engine bounce around when you rev it. There's probably enough torque in your V8 to rip a cracked mount if you stomp on the gas.
A tune up is the best bet unless you've done one recently. Good luck.
CP
