my distributor wont go back in
#22
knuckles:
when you have the distributor 180 degrees out you _don't_ have to pull it again. just swap all plugwires on the cap with the exact opposite one. job done.
make sure you have the firing order correctly (distributor turns anticlockwise)
if it backfires you might just be too far advanced or retarted.
Try turning the distributor while someone starts the engine.
if it goes whoooop whoooop instead of whopwhopwhop it's usually too far advanced
it back fired hard and wouldn't fire (start) at all. and i was jumping it from the solenoid with the key in the on position so i could turn the distributor. my dad just dropped off his timing light so that will help me tremendously.
#23
i thought at first wow, alot of people want to help me with this little problem? but then i realized the 16 year old pennslytucky native was spamming
#24
hitting distributors with a hammer is scary ****, but instead of moving the cables around in some distributors you can turn the rotor by 180 degrees (pertronix has two screws to hold the rotor and you can turn by 180) ... anyway lessons learned, aye ?
the timing light will help finetuning, but for the initial setting it's quite worthless as the timing mark will be way off the marks if it's not even running, you have to get it at least so-so running before you can fool with timing light. start from scratch:
- verify TDC: remove spark plug #1, place finger over hole to block it (or shove a rag to block hole, not into the cylinder), turn engine manually until you feel pressure. That's just before #1 TDC.
- align the distributor so that the rotor points just next to #1 spark plug. as it turns anticlockwise the rotor should be off by a tad in clockwise direction. you can drop the distributor there and adjust with turning. best thing might be a little mark on intake or somewhere were the rotor is pointing to, then you have it easier to see with the cap on while turning.
- verify the firing order. start with #1, go anticlockwise. If you changed cam, you might have changed firing order
make sure you have all tools, rags, fingers out, sparkplugs back in and boots back on. this should be good enough for starting it while turning the distributor a few degrees in either direction
