Squeek Squeek
I've been running poly on my strut rods for years without issue. Don't over tighten the nuts on the strut rod and overcompress the poly, not giving it enough space to move around. And I wouldn't be so certain that them snapping has anything to do with poly, it's a structural steel rod which bends and flexes a great deal, if the strut rods are snapping then it's because the steel reached it's failure point, probably because it had been overtightened so that it passed the yield point and wouldn't return to normal tension, and every time after that it was tightened it just stretched farther, until it finally failed under a load.
And poly squeeks and rides stiffer, the trade off for keeping the suspension more positively located.
Poly squeaks. Factory upper A arms have a grease fitting that's only reachable with a special grease gun extention that most garages no longer carry, and aftermarko sway bars don't have grease plugs at all. One guy posted that he drilled them in and cut a grease channel in the bushing.
I looked extensively a few years ago and could not find a vendor that made real rubber bushings.
Sorry, I don't have a solution to offer except to use silicone grease like Adrenolin said and add teflon tape to your sway bar.
It's like a bunch of mice having an orgy under the hood. I hate it.
I'm redoing my front suspension in 2 months and will be checking this thread myself for any new suggestions. Good luck.
CP
CP
I had them in one of my Mustangs several years back. I wound up carrying a spray can of silicone lubricant in the trunk. When the squeeks drove me bonkers, I'd get out and spray them with it. It worked for a while, repeat as necessary!!!LOL.
NEVER,NEVER AGAIN in any car I'll drive!!!!!
Jay
Jay
