Shock Tower
Shock Tower
So Today I was diggin around and notice that the the left shock tower bolt was loose, and the right was tight to the point that it was crushing the rubber bumper, Any ideas why or what I should do there? I'm still waiting for my shop manual to get here but I dont want to waste any time
Are you talking about the small rubber bumper at the bottom of the part which can be known as the Outer Shock Tower, Coil Spring Cover or Shock Tower Brace? It goes by all those names. My 65 shop manual refers to it as a Coil Spring Cover. The shock tower is on the inside of the engine bay and the part I asked about is on the outside. The bumper is held on by a single bolt and is just there in case you bottom out.
2+2GT-Any idea why someone would have taken them off?
tx65- Will the one piece ones that say 64-73 actually fit without major adjustments? So far I can only find the ones that say 64-73 at cjpony, the other places I've looked have listed it fitting 64-70 mustangs...
And I'll get pictures and post them later today of the spot I am talking about.
Call Glazier's about the braces, and while you're on the phone you might want to get their "G05024 71-73 front shock Hardware" which will give you the upper and lower bushings, washers, and nuts for one front shock. Get both if you need them.
http://www.mustangbarn.com/
Yeah that is the shock bolt that looks loose.If it was my car i would replace both shocks and put the export braces back or http://www.mpgheads.com/ sells a custom one that fits the 71-73.A site you will like http://www.7173parts.com/ is full of info and http://429mustangcougarinfo.50megs.com/ same way.
