Tapping Noise. - Page 2 - MustangForums.com
Old 06-22-2009, 01:56 AM   #11
AlexZi
AlexZi's Avatar
This is highly possible, as the guy who did the exhaust has scheduled for me to return in 10-14 days to torque down/re-torque the headers...
Hopefully thats all it is. The only thing is that this sound was there before. Maybe I had an exhaust leak before too...heh.
AlexZi is offline   Reply With Quote
Old 06-22-2009, 03:46 AM   #12
CyprusMustang
check this easy thing out, just to rule it out, jack up car a little, get a 9/16 wrench and take off the 2 screws that cover the flexplate on the bottom of the tranny. its very easy, then start her up and see if the noise went away. perhaps the plate is on backwards or its bent. perhaps your screws on the flexplate are rubbing somewhere.
CyprusMustang is offline   Reply With Quote
Old 06-22-2009, 05:43 AM   #13
tx65coupe
tx65coupe's Avatar
Quote:
Originally Posted by Starfury View Post
I'm with 67mustang302. I think it's an exhaust leak. I have several, so I should know the sound
Thats what I was thinking as well.
You can get a mechanics stethoscope for about 8 dollars. A'zone or Advance should have it. Its nice to have. You can use it to check for valvetrain noise, lower end noise, or even just the pulleys.
tx65coupe is offline   Reply With Quote
Old 06-22-2009, 11:03 AM   #14
AlexZi
AlexZi's Avatar
Sweet. Will do. Im going to go out side and have a look at some things.
Old 06-22-2009, 01:35 PM   #15
67mustang302
I gave up trying to seal all the leaks at my header collector. Tick tick tick tick etc.
67mustang302 is offline   Reply With Quote
Old 06-23-2009, 05:07 AM   #16
tx65coupe
tx65coupe's Avatar
You can also check for exhaust leaks with the car running. Just use your hand and feel for exhaust coming out somewhere it shouldn't. This works better the farther you go back on the exhuast. It doesn't work that well right at the motor since the fan is moving air. Also you can look for black exhaust residue somewhere that would indicate that there is a leak.
Old 06-23-2009, 05:12 AM   #17
tx65coupe
tx65coupe's Avatar
Here is what I was talking about. I guess it went up a couple bucks its a little over 10 now.
http://www.jcwhitney.com/autoparts/P...tt=stethoscope
Old 06-23-2009, 01:49 PM   #18
1965fastback
1965fastback's Avatar
Do you have a fan shroud? If so it may be hitting the fan because my mom's 68 did that for a while till I fixed it.
1965fastback is offline   Reply With Quote
Old 06-23-2009, 03:42 PM   #19
AlexZi
AlexZi's Avatar
Quote:
Nope, no fan shroud here.
Old 06-23-2009, 08:01 PM   #20
1965fastback
Then I'd have to go with exhaust leak.
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 05:23 PM
Chirp during hard shifts? 6bangr 4.6L V8 Technical Discussions 5 02-15-2016 08:40 AM
Time for a new clutch? MasterLanMan 4.6L (1996-2004 Modular) Mustang 6 09-13-2015 09:21 PM
Loud Noise Above 30 MPH bjdutch2005 2005-2014 Mustangs 8 09-07-2015 11:05 PM
03 V6 Mustang Ticking Noise Emblazoned General Tech 0 09-03-2015 11:45 PM
1965, 289, adjusting, clanking, ear, engine, ford, half, idling, mustang, noise, rpm, speed, tapping, v8, valve, valves
