Tapping Noise. - Page 3 - MustangForums.com
Old 06-24-2009, 05:56 AM   #21
CyprusMustang
did you check to see if the flywheel is hitting on the cover? its the easiest thing to check.
CyprusMustang is offline   Reply With Quote
Old 07-31-2013, 07:32 AM   #22
Tyler Cole
Default HEY IM IN NEED OF HELP BAD
Quote:
Originally Posted by AlexZi View Post
Hey guys. Ive had a tapping noise coming from my stock 289 for a while now. I can hear it louder now after I put a new exhaust system on, and its very noticeable. I was wondering if anybody could diagnose the problem as Im guessing its not normal for this to be happening. You can hear it clearly in this video. The car was in drive and I was hitting the gas lightly. Its much quieter when the car is idling in park.
http://www.youtube.com/watch?v=zj2lc...eature=channel
I HAVE THE EXACT SAME PROBLEM WITH MY MUSTANG RIGHT NOW AND IT HAS NOT BEEN DOING VERY WELL EVER SINCE I RAN MY CAR OUT OF OIL ANY IDEA ???? DID YOU FIX YOURS YET
Tyler Cole is offline   Reply With Quote
Old 07-31-2013, 11:41 AM   #23
Gun Jam
Moderator
Gun Jam's Avatar
Its not the exact same problem.
The person who started this thread almost certainly had an exhaust leak unfortunately for you...you do not have an exhaust leak.
How long was your engine run without oil?
how did the engine become low on oil to the point where it "ran out"?
Based on my initial impression the fix is simple....a crate motor!
-Gun
Gun Jam is offline   Reply With Quote
Old 07-31-2013, 03:06 PM   #24
69thunder
Ran the engine out of oil? Did it all leak out or did you not ever check it? If you really ran it out of oil the engine is toast.
69thunder is offline   Reply With Quote
Old 07-31-2013, 04:03 PM   #25
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
Is that an original engine with the stock heads? If those are the original heads with the original valves then your heads are probably hammered and clapped out from not putting a lead additive in your gas.
If it is then turn up the radio and party 'till it pukes. What noise?
fastbackford351 is offline   Reply With Quote
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 05:23 PM
Chirp during hard shifts? 6bangr 4.6L V8 Technical Discussions 5 02-15-2016 08:40 AM
Time for a new clutch? MasterLanMan 4.6L (1996-2004 Modular) Mustang 6 09-13-2015 09:21 PM
Loud Noise Above 30 MPH bjdutch2005 2005-2014 Mustangs 8 09-07-2015 11:05 PM
03 V6 Mustang Ticking Noise Emblazoned General Tech 0 09-03-2015 11:45 PM
1965, 289, adjusting, clanking, ear, engine, ford, half, idling, mustang, noise, rpm, speed, tapping, v8, valve, valves
