1967 Mustang 289 Stumbling
My '67 has a rebuilt 289 in it. Carb is a 4 barrell Holly.
It is stumbling out of the gate but runs great once past that. I have added a 1" spacer between the carb and the intake but that did not do it. I have changed the squirters/nozzels from a 31 down to a 28 but still no change....
The timing has all been set properly to spec.
Help??????
I do not know what to try next??? A larger nozzel???
Thanks
Help??????
Thanks
Define stumbling? What's the engine setup and what's the timing and plugs/gap? Does it bog and get lazy or kind of sputter and then slowly pick up till it's fine? Or does it just fall flat like it tries to stall out and then suddenly pick up and take off? The former is typically too rich, the latter is typically too lean, for the pump shot. When you changed squirter sizes how did it effect how the car performed? What pump cam is in it? What do the plugs look like, is it running rich or lean?
The squirter change did little to nothing, worse if I had to really say.
It tries to stall if I gun it but if I feather it I can get through then gun it and be ok. From a dead stop, if I gun it, it will want to stall. If I am already cruising and gun it, it is ok too.
It doesn't need to be replaced unless it's leaking or damaged so that it isn't delivering fuel properly. I wouldn't listen a whole lot to other people about carbs when they can't specifically say why you should do something(and even then take it with a grain of salt). Most people just don't really understand how they work.
Try a cam that delivers more fuel or has a more aggressive rate, if that helps but doesn't solve the issue, then use a larger squirter. The next size up on a Holley from a 31 is a 35 I think. Quickfuel sells a 32 and a 34.
Stumbles and bogs are mostly caused by too much fuel or not enough (i.e. dead rich or lean). Without an AFR gauge, it is hard to diagnose and tweak the accelerator circuit. I would put your squirter (nozzle) back to stock size and change the pump cam position or curve to something that will give you more fuel earlier. Larger squirters (nozzles) will cause fluid to enter the carb faster for a given throttle position but does not change the amount of fuel entering the carb for a given throttle position and going too large can cause atomization issues. The pump cam will change the amount of fuel that enters the carb. Try changing the pump cam position and/or pump cam first. Here is a link to the different cam colors and curves. Let us know what cam color and position you are currently on so we can help you pick a new one to got with.
http://www.carbdford.com/tech/Holley20PumCams.gif
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
