Rack and Pinion upgrade from RC Motorsports
Was looking at upgrading to power steering, figured what the hell, lets drop some serious coin and do this once and do it right. Front suspension definitely needs updating anyways.
Anyone used this kit, more specifically the 107?
here's the site
http://www.rcmotorsportsinc.com/index.html
here's the site
Thanks for posting CPR. I'm very new to this, not very savvy with cars, I'm crossing over from a Motorcycle background. Honestly after dropping $2k for Termi exhaust or Ohlins forks for one of my MC's this kit seems like a bargain. But like I said, I'm new to this. What I hope to achieve is to get "best bang for my buck" type of suspension/brake set up. My car already has front disk brakes but the suspension is a bit lacking. No power steering either leaves me wanting to tackle the suspension/handling issue first.
It sounds like you know what you're talking about so I've gotta ask:
If you were planning on using a 1966 289 Mustang as frequently as possible for 20-30 mile city commutes, what suspension/steering upgrade would you go with that would give you the "best bang for your buck?"
BTW,
Nice shop, checked out the link to your shop. One more question, if that dark (black/blue?) Mustang coupe on your main webpage is a 1964,65,66, what size wheels/tire combo are you running on that? I've been shopping around for wheels too and find myself attracted to those Cobra-style wheels.
Thanks again.
That black one is a 67. If I remember it was 8 in the front and 9.5 in the back. And they were vintage rims. Best bang for the buck could be stock suspension with upgrade and a upper arm drop. That does handle really well. Add a power rack from almost anyone other than flaming river. TCP's stuff is the ****, but will be about 6k for rack and front suspension. An AJE kit I like better than the MII. Comes with a rack and you can cut the towers back a bit. For about 3500 you can get the aje stuff with 13in rotors up front. There will be no lacking in that brake setup. lol
Looks like a front suspension kit from TCP (coil-over spring conversion single adjuster) kit will run about $2400 + add the $1000 power rack and pinion from another co. (i.e. randallsrack) and the price is about $3500 + labor. I wonder if the $2500 kit from AJE with install (extra cutting and modding) will add up to close to what the labor + TCP + randalls power R&P would run.
Eh, you don't have to cut the towers like in the pics. If you notice, the one on the right isn't cut back. But if you do a rack from another company like Randals, I remember the kits being closer to 2k than 1k. So ur closer to 4500 with the TCP stuff. The AJE saves you about 100lbs on the nose because you get rid of a lot of metal. Some you don't HAVE TOO get rid of though. All said and done, the AJE would probably be about 1k more if you have someone install if all for you. But that's with 13in brakes, where as with the TCP, you'd run what you have, or pay to go bigger on top of what is already typed. Same brakes on both kits, I guess would be really close. But the TCP stuff will handle better.
I just wanted a rack really bad for mine. So I did a basic kit, and went to the junk yard and got '95 brakes. 12in in the front for me will be plenty with 12 in rotor in the rear
KingRando
10-02-2015 08:06 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
