Stalling when turning fast
Old 06-26-2009, 07:38 AM
wjkingsnorth
wjkingsnorth's Avatar
Default Stalling when turning fast
I have a 1965 Mustang Coupe with the straight 6 200. The car runs good when I am going straight or not doing a quick turn. Here in Michigan we have whats called a Michigan U turn. If you are from Michigan you know what I mean. If I do the turnaround too quickly the car stalls out. Of course I can go slower, but there is still an issue that needs to be fixed. If anyone has an idea, please let me know.
wjkingsnorth is offline
Old 06-26-2009, 07:54 AM
fakesnakes
fakesnakes's Avatar
I'm not sure how you adjust the carb float level on that engine, but that sure sounds like the issue.
fakesnakes is offline
Old 06-26-2009, 07:59 AM
fakesnakes
fakesnakes's Avatar
rigm frigm dp
Old 06-26-2009, 11:31 AM
Stepman
Stepman's Avatar
Yeah, I remember those U-turns. Takes some getting used to but traffic flows better.
It sounds like your float is too low to me too.
Stepman is offline
Old 06-26-2009, 12:15 PM
03BottleFedGT
03BottleFedGT's Avatar
get used to it mines been doing it for 12 years ive replace carbs, floats,and adjusted it still did it till the day i pulled the 6 cyl out
03BottleFedGT is offline
Old 06-26-2009, 01:04 PM
kalli
kalli's Avatar
move house :-) nah. i'm with the others. try floats first
kalli is offline
Old 06-27-2009, 01:46 AM
tx65coupe
tx65coupe's Avatar
I agree.
tx65coupe is offline
Old 06-27-2009, 07:43 AM
1965fastback
1965fastback's Avatar
To adjust the float you have to pull the top cover off the carb and bend the float arm slightly up.
1965fastback is offline
Old 06-29-2009, 03:35 PM
my 67
my 67's Avatar
I heard this has always been an issue with 1bbl carbs. I also have an I6, but mine runs rough at idle.
my 67 is offline
Old 06-30-2009, 01:51 AM
MayorDaly
MayorDaly's Avatar
You may not getting enough fuel preassure to keep the bowl full , so it spills to the side when turning at higher speeds, and chock out. Try installing a electric fuel pump and bypass your mech. pump. You can also get a fuel regulator and try some different settings untill it works for you.
MayorDaly is offline
Quick Reply: Stalling when turning fast
