Gaa! Electrical nightmare.
Yeah, even with a brand new battery, alternator and regulator (you know, working ones) I've never gotten a reading of more than 12 and change.
The current regulator is brand new, but it is just a $15 four wire from advanced. Maybe I fried it somehow while i was fiddling with the alternator. Tomorrow morning I'll drive out to the NAPA and get an electronic regulator. I'll post as soon as I get some readings.
*Also* Are there any notorious weaknesses in that wiring harness I should be looking for?
As for weaknesses, corrosion in the connectors is always a problem on older cars. Clean them with Brasso using Q-Tips and an old toothbrush, and grease them with silicone dialectric grease. This is the ONLY way to get the factory ammeter to work, by the way.
Yeah, the case is aluminum or some soft metal of the like. I would take your current alt. in and compare it to a few GM alts. as I can't remember what make it was for, but I remember it was the first time they had internal voltage regulators.
Hopefully, the final post:
I was suspicious of those the wiring harness. I used a seam ripper from a sewing kit to do a few harnessectomies, ie I slit the outer wrapping of the harness to take a look at the condition of the wires inside. The only place the wire looked really bad was the top of the harness where it connected to the alternator, battery, etc. I cut off the top foot or so and spliced in shiny new wires, and viola! I'm back up and running. Its current;y operating at about 12.75/12.4.
Those numbers that 2+2 was throwing around made me realize that I must have "leaks" all over the system, so I think the next step or a re-wiring of everything in the engine compartment. I found some pre-assembled wiring harnesses here:
http://www.virginiaclassicmustang.co...sp?itemid=WG34
The harness for the dash is $500, which seems high, but the ones ill be dealing with only look like $95 + $15.
Many thanks to all of you who weighed in on this one. My main fear was that this would be some weird, pony-specific issue that I didn't know about.
mrappe
09-26-2015 10:16 AM
TfcCDR
09-14-2015 12:08 PM
