Bar?
Old 06-29-2009, 10:09 AM
SJs 66coupe
SJs 66coupe's Avatar
Default Bar?
I was given a Monte Carlo bar for Father's day but wondering if anyone has ever installed one?
Started to put it on the other evening but if fits tight, like really tight.
Any ideas or suggestions?
If felt like to get it in place I was going to have to get out a rubber mallet.
Did anyone else have any issues with this?
SJs 66coupe is offline
Old 06-29-2009, 10:21 AM
Gun Jam
Moderator
Gun Jam's Avatar
yeah I had to pound mine in with a block of wood and a 3 pound hammer.
I have heard that jacking the front end off the ground may help.
-Gun
Gun Jam is offline
Old 06-29-2009, 10:25 AM
andrewmp6
andrewmp6's Avatar
Beat it on or the old jack it up over night let the front end spread out.
andrewmp6 is offline
Old 06-29-2009, 10:43 AM
SJs 66coupe
Thanks for the tips....Just wanted to confirm they were supposed to be that tight and make sure I didn't have a bar with a manufacturing error or something along those lines.
I had the front end of mine on stands because I had to take the front wheels off to get to the bolts.
Stupid like, I didn't think to buy the bar and install it when I had the front end taken apart, duh....
Old 06-29-2009, 11:57 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
mine is not that tight, jack up the car from the engine cross member(after 45 years the tower sag in towards the middle of some cars) it will take a few hours for them to relax
rmodel65 is offline
Old 06-29-2009, 12:49 PM
SJs 66coupe
Stupid question warning but do you mean the front cross member?
Old 06-29-2009, 01:53 PM
Flash70
Flash70's Avatar
Its the bar that goes across the bottom of the compartment underneath the engine. Pretty sure thats what he means because thats the engine crossmember the top ones are the compartment crossmembers i think.
Flash70 is offline
Old 07-01-2009, 11:07 AM
crunchyskippy
crunchyskippy's Avatar
Yep. Its tubular, and is strong enough to lift the weight of the car.
As a side note, I had a harder time installing my monte carlo bar than installing my export brace.
crunchyskippy is offline
Old 07-02-2009, 10:30 AM
jspagna1
jspagna1's Avatar
Definitely jack up the car and let it sit overnight. This will make your life much easier when installing the bar. It's may take some persuasion. What I also found that helped was to get the bolts started and work each side a little at a time drawing the bar into place.
http://www.cardomain.com/ride/2576315
jspagna1 is offline
Old 07-02-2009, 10:38 AM
Norm Peterson
Norm Peterson's Avatar
Use a bottle jack + an appopriate length of two by four placed horizontally between the fenders Jack them apart enough so that the bar will drop into place. It shouldn't require much movement.
I'd be a bit concerned if the distance between the fenders continued to open up overnight with the front end of the car jacked up - something would have to be bending or otherwise being overstressed.
Norm
Norm Peterson is offline
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
fastbackford351
10-01-2015 12:24 PM
winner99
10-01-2015 10:52 AM
09-16-2015 07:53 PM
Quick Reply: Bar?
