upgrading the T5 - MustangForums.com
Old 07-01-2009, 10:50 PM   #1
66fstbk88
Default upgrading the T5
I got a 351w pushing way to hard for these T5's that I keep chewin' up. Any suggestions on what to do. I drive it about 4 days a week, so I was thinking about a toploader, but I do need the overdrive. I was thinking about T56 or TKO. I don't really know how much work is involved.
Any ideas from people that have done this?
66fstbk88 is offline   Reply With Quote
Old 07-01-2009, 11:08 PM   #2
.boB
Skip the toploader.
A tremec 500 would be a drop in replacement. The 600 uses a differant input and ouput shaft, and would require a new clutch disc and drive shaft yoke. If you go that route, contact Mike Forte at FortesParts.com. He can get you everything you need. Prices are good, and service is better.
If you're beating it up on the road course, contact Gordon Levy at LevyRacing.com. He can build you a T5 that will match your purpose and last forever.
.boB is offline   Reply With Quote
Old 07-01-2009, 11:53 PM   #3
racin66coupe
racin66coupe's Avatar
i like the levyracing.com !
racin66coupe is offline   Reply With Quote
Old 07-02-2009, 01:55 AM   #4
Is1BadFord
Is1BadFord's Avatar
Quote:
I'm not sure what kind of car you're running, or what gears or tires (tires are like a replaceable fuse!) you have...but I ran a T5z behind a 500hp+ N/A 347, in a 10.70 2850lb daily driver Mustang for two years without issue. The z spec T5's are rated slightly higher than a standard unit, but not enough to make that much of a difference.
I guess what I'm saying is...rather than blame the 351...possibly you might consider how you're driving/shifting it? That's no insult!! An aftermarket shifter with positive stops (Pro 5.0) is an absolute necessity. Upgraded shift forks are also very much recommended. Additionally, no matter how 'hard' you drive it...you always have to keep in mind what you're shifting. Crisp, 'well aimed' shifts that aren't over powered do more for the life of a T5 than any single internal improvement. I mean, if I could run 10.70's with one behind a 347...it's clear they'll take hard shifts and a good bit of abuse =D.
Hope that helps!!
Cris
Is1BadFord is offline   Reply With Quote
Old 07-02-2009, 01:58 AM   #5
Starfury
Keep in mind, neither the TKO nor the T56 will fit under your tunnel without some sort of modification. You'll either have to hack up the tunnel or use a drop crossmember. If you do the latter, you'll need to account for the change in transmission output angle compared to pinion angle. You can probably get away with using Ron Morris adjustable motor mounts to drop the engine as well, fixing the angle problem.
Starfury is offline   Reply With Quote
Old 07-02-2009, 10:15 AM   #6
racin66coupe
i beleive the guys at american powertrain ( americanpowertrain.com ) have tko's and t56's modified to fit in the tunnel without a drop member or modified tunnel
Old 07-02-2009, 11:42 AM   #7
Starfury
True, forgot about that.
Upgraded PaulH2 Members Rides and Car Show Section 20 01-31-2016 10:48 AM
Rear Package Shelf jrrhd73must Classic Mustang General Discussion 2 10-02-2015 10:17 PM
UPR Products Rockin the Lethal Performance Grille Delete Combo! Boostaddict Lethal Performance 0 10-01-2015 09:58 AM
UPR Products Rockin the Lethal Performance Grille Delete Combo! Boostaddict 3.7L V6 S550 Tech 0 10-01-2015 09:57 AM
GT500 front LCA question UrS4 S197 Handling Section 1 09-30-2015 11:13 AM
23, morris, ron, t5, t5z, toploader, upgrade, upgrading
