Ignition Diagnosis, pa-leeeze!
Old 07-01-2009, 10:29 PM
runway1
runway1's Avatar
Default Ignition Diagnosis, pa-leeeze!
It's a 65 coupe with a 289. In Aug, 08 I replaced the stock points/cond with a Pertronix II and Flamethrower coil. Driving along, running like a top, it just died (posted thread two days ago but I have more info today). Car won't start.
- Coil sparks both directions (From coil and into dizzy)
- Carb spouts/coughs liquid gas - no smoke or flames
- Replaced cap/rotor hours ago with no change
- There's spark at the plug-to-wire connection but I can't tell if it's sufficient...seems weak and varies plug to plug.
- Attached timing light to see if I have enough voltage to light it and BAM, timing light does not "light" when cranking.
I think that's it. My diagnosis is the coil. Any suggestions? You've all been much help in the past and I want to say thanks to all in advance!
P.S. I've heard the Flamethrower coils are questionable. What coil would you suggest in its place?
runway1 is offline
Old 07-01-2009, 10:42 PM
1slow67
ROTM Moderator
1slow67's Avatar
The flamethrower coil I have used lasted only 3 months on just an ignitor I setup. The regular stock replacement coils work better than the expensive ones do for me.
1slow67 is offline
Old 07-02-2009, 12:05 AM
JMD
JMD's Avatar
I have to agree, oem style coils seem to last better than some brands. My brother in law's accell coil was a pos, as was it's replacement, both lasted less than 3 mo.
I recommend buying a stock style coil as a cheap means of trouble shooting at the least, and IMO as a viable perm replacement.
Most of the benefit of an electronic ignition will be in the better dwell characteristics. While a "super coil" will throw a harder spark than a stock replacement, the oem coil is more than sufficient.
IMO a stock duraspark coil might be the best comprimise...
JMD is offline
Old 07-02-2009, 12:52 AM
Starfury
Starfury's Avatar
Coil is definitely the first thing I'd suspect. If you go aftermarket, MSD coils are great, but they need a full 12V source. Otherwise, a good OE replacement coil (like Napa's Echlin brand) will work fine.
That said, it's still possible the Ignitor is fried. They're known to do that, unfortunately...
Starfury is offline
Old 07-02-2009, 09:27 AM
runway1
runway1's Avatar
Thanks, all. I start with that coil and see what I got.
runway1 is offline
bradleyb
11-27-2015 07:50 PM
piotrek53
10-13-2015 06:54 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
jessicarabbit
09-25-2015 12:41 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: Ignition Diagnosis, pa-leeeze!
