transmission fluid leak
I'm down to my LAST leak! I have transmission fluid coming from someplace up on the passenger side of the transmission. It's a C4, and it looks like it might be coming from a small metal plate about 4 inches square. What's behind this plate? Fluid level should be well below this, no? Can I just remove the plate and install a new gasket?
leak
WOW! Thanks for the pic. I know when I put the engine/trans back into the car 15 years ago, I had one helluva time getting those connections made up and tightened, so it's VERY likely that the one above the plate might be loose. I've since acquired tubing wrenches, so this should be one quick fix! Thanks again - a picture is worth a thousand words!!
jwog666
12-27-2021 08:09 PM
KingRando
10-01-2015 11:16 AM
09-25-2015 06:42 PM
