Secondary Exhaust/ Crankcase Ventilation?
Old 07-06-2009, 05:03 PM
Wraith88
Wraith88's Avatar
Default Secondary Exhaust/ Crankcase Ventilation?
I have a '65 3.3 6cyl automatic. There is a 1 inch steel pipe that comes out the left side of engine by cylinder one. It is apr. 1 ft long, ports exhaust smoke of some kind and ends below engine putting exhaust gas into engine compartment and hence into passenger compartment. Can someone tell me what purpose this is supposed to serve and where it should be leading to instead of below engine?
Thanks in advance for your insights!
Wraith88 is offline
Old 07-06-2009, 05:41 PM
jlg2002
jlg2002's Avatar
Hi Wraith88,
I don't think your 65 came with a 3.3 L engine (unless a 200 CID is a 3.3). Are you sure it's connected to the exhaust system? They did have road draft tubes on early 60's engines. These tubes vented the cranckcase blow-by overboard. In later cars, the created the PCV system and then finally when to a totally "closed" system that had a PCV and a tube from the valve cover (oil cap) to the air cleaner.jlg
jlg2002 is offline
Old 07-06-2009, 05:46 PM
1slow67
ROTM Moderator
1slow67's Avatar
The 200 is a 3.3.
Can you post a picture of the tube?
1slow67 is offline
Old 07-06-2009, 05:53 PM
HGC
HGC's Avatar
Originally Posted by jlg2002
Hi Wraith88,
My 289 has one of those and I really hate it. It comes out of the left valve cover and down below the car. It is bolted top and bottom. I had to wrestle the damn thing completely off to get the valve cover off, and putting it back on was even worse. I believe it causes suction as the car moves forward which then pulls out the blow by. I can see it venting some sort of stuff when the car is just ideling. Given it's location that vented gas is going to end up in the area of the passenger compartment unless everything is sealed up real well.
HGC is offline
Old 07-06-2009, 07:16 PM
1971mach1
1971mach1's Avatar
It's easy to convert over to a PCV system. You just need some valve covers
that have the fittings, a hose to the carb, the breather and PCV valve. The origional valve covers may be able to be adapted but it's cleaner just to get new covers. Then you won't have to breath that stuff too.
1971mach1 is offline
Old 07-07-2009, 01:13 PM
Wraith88
Wraith88's Avatar
Thanks all for your input. It is the 200 CID. I'm not sure if it is the same as the port from the valve cover on the 289. This does not come off the valve cover but specifically off the engine block. It puts out a lot of smoke. Is it really just supposed to be where it is? Has anyone ever redirected the output on one of these to somewhere else?
Wraith88 is offline
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
trashxtrash
09-20-2015 10:49 PM
YoungStangsMan
09-05-2015 07:01 PM
dochawk
08-25-2015 08:25 AM
skiter
05-26-2004 05:46 PM
Quick Reply: Secondary Exhaust/ Crankcase Ventilation?
