Broke 68 Front Bleeder Valve
Just bought a project 68 coupe. Brakes were mushy so I decided to flush out old brake fluid and bleed each brake. Rear drums bled just fine. Moved to FR and as soon as I touched the much smaller bleed valve it cracked (may have already been cracked). How do I get the valve out now that it is about to come off. Two different mechanics say I can't remove the valve and that I need to replace the clinders/calipers for big $$ when all I need is a $1 part. Only have about 2 inches of space to work with as the wheel mount(?) rod is right across from the valve. I believe the front brakes are disk as the drum/brake housing is different from the rear drum.
Thanks for the reply...I don't know if they are drum or not. The rear brakes are definitely drum, pulled the 5 hole drum off the lugs to check the pads. On the front, I didn't pull off what appears to be drums but I did notice the lugs are part of the cover/drum. There is not your standard disk with calipers on both sides unless it is contained within this housing/drum. I'll look tonight. While I'm in there, anything I need to look at specifically, regarding the bleeder valve, cylinder/calipers?
sounds like you have drums to me. pics would help though.
if you do have drums all you have to do is replace the ( the name is blanking on me) cylender that the bleeder screws into. a lot cheaper than a caliper
Thanks KMatch. Pretty sure I have the original 289, rebuilt, but original. Will O'Reillys know the bore? Does the bleed valve pass thrugh the housing and into the cylinder? If it does how do I get the cyninder off? Will I need to remove the remains of the valve from the inside? If so, how. Unfortunately I'm not sitting in front of the brake and I'm just trying to visually put this all together.
No offense intended, but you are dealing with drum brakes and getting all the springs in the right place, while not terribly difficult, does require some mechanical skill and knowledge, which it doesn't sound like you possess. I think you should take it to a brake shop and let them fix it for you. Brakes are not something to guess with.
Again, I mean no offense.
The wheel cylinder (provided you really do have drum brakes) resides inside the brake drum. It spreads the shoes which applies the brakes. The "valve" or bleeder you're referring to will never be seen again. It's broken inside the cylinder which needs replacing. Forget about it. Things of a critical nature: Proper installation of the brake shoes and EVERY spring. Proper adjustment of the shoes to the drum once finished. Proper bleeding. Proper wheel bearing packing AND torque. Too tight is worse than too loose. Are you up to this?
OK, we're getting into a little gray area here, and as T.A.M. points out, I'd hate to lead you into a job over your head. First, no parts store will know what size bore you have without some input from you. The specs I gave are from my ordering screen and are exactly what you will be asked: Engine size and maybe bore size, then you take it and check to see if it's right. Now, while "I" can swap one out in a matter of minutes with a little creative spreading of the shoes and no major disassembly, I have no idea what your abilities are. Everyone has to start somewhere, but brakes ain't a good starting point for safety reasons. You either have a good level of common sense or pay someone to help or do it.
We'll see if I'm up to it; I'm not so macho that I won't pass to job to a pro if I can't handle it. I haven't worked brakes in 30 years. Right now the broken bleeder valve is not leaking so it's not a rush job so I have time to "refresh" my skills. Never changed a cylinder, just the shoes and made adjustments. Thanks for the help. As far as the diameter goes I can get that from the other side, assuming I don't crack that one as well.
