Headers or Exhaust
Headers or Exhaust
what is the best to go with as far as HP we had tri-y before and want something different ,,wanted shroties but no go because of z bar ( clutch ) was thing about hi po exhaust that would solve everything right the pitman are hit the tri-y we had to bend them very bad to use them so what do you all think ????
thanks
thanks
Hedman makes a wide variety of long tube headers for Mustangs and they are pretty decent on there pricing compared to Hooker and some other brands. JBA makes an awesome mid-length header that will clear the Z bar but they are a little bit more money. My dads currently running a set of JBA mid-lengths w his AOD and they are a well designed excellent quality header.
What is the best to go with as far as HP? We had tri-y's before and want something different. I wanted to run shroties but it was a "no, go" because of z bar. ( clutch ) I was thinking about a hi-po exhaust, would that solve it? The Pitmans hit the tri-y so I did need to bend them. (very bad) what do you all think ????
thanks
thanks
I would go to the hooker headers if you wanted to change brands. I would not go to shorty headers, they do not give you horsepower and torque gains like long tube headers. I would not go back to hi-po exhaust manifolds, they are too restrictive.
I switched from tube headers to HP manifolds after years of dealing with the heat, noise and leaks of the tubes. Other than a tiny power loss at very high rpm, no problems at all since then, and how often do you tach it up to 6000? With me maybe a couple times a day, but most even less than that.
About the Tri-Y getting hit by the equalizer- Use the 289HP equalizer, and if necessesary, use a 65 upper rod and 66 lower rod to get more adjustability.
The 289HP equalizer tucks the lower arm closer to the engine block. The 65 clutch was adjusted using a threaded upper rod. The 66 was adjusted using a threaded telescopic lower rod. Using the 66, you simply make the rod a length that will not contact the Tri-Y's, then adjust the linkage 65 style using the upper rod.
