Confusing Ignition Problem
My son was driving along with an engine that's been humming and running very well and then BAM, it just died. It has a Pertronix II module that we were concerned about and an original '65 dizzy with a crack in the housing.
So, we replaced the whole unit with a Mallory HEI and still have no ignition. We have fuel - pumping along just fine. Compression is about 90 psi - seems low but good enough for ignition – and we have spark at the plugs, although it doesn’t seem very strong.
Compression, fuel and spark. Why no ignition? It doesn’t even seem to baaaarely kick over. It has that turning sound as if you pulled the coil wire. I’m measuring 12v at the coil (12.25v). Could it be that somewhere I have a frayed/loose wire that may somehow be limiting the current flow? Could 12v and a weak current (amps) screw up ignition? Any suggestions?
TfcCDR
09-14-2015 12:08 PM
