what gears should i use for my 69 stang 302 rear end?
im redoing my rearend and am torn between going with a 3.55 or 3.80 ring and pinion setup (unless someone has a better idea! lol). my 302 is stock with a few mild mods right now, and the stock 3 speed tranny. what should i do?
thats what i was thinking...its a mild car but with that upgrade from the stock gears should make a big difference for me without spending a fortune. how much of a difference will i really notice going from the stock 2.70-3.00 (not sure which) to a 3.80?
Here's a gear calculator, plug in your tire height, tranny should be 1:1 in 3rd and different gear ratios and it'll tell you what RPM you'll be at at different speeds. I made a spreadsheet so I could compare across the lines and put in 50 -110mph to see what it'd do to my RPM's.
I mainly looked at 70-80mph since that's my interstate cruise speeds to see what RPM's I'd push for sustained hwy. driving (>15min. worth).
http://www.ringpinion.com/Calc_RPM.aspx
Jon
Jon
