Electric choke placement
I plan to do an electric choke conversion soon and was looking for the best place to get the voltage from. I have been told to run to the coil, ignition, fuse block and other places. How is yours set up and do you mind posting a photo?
the choke needs 12v to operate, and after bypassing your stock ignition resistor wire, you will be getting approximately 12 volts at your coil, making it a suitable place to draw power from. just take the red power wire from the choke to the + side of the coil and you're good to go.
from here
to here
from here
to here
yeah thats the main benefit imo of putting it there: convenience. is it the absolute best place to put it? probably not. but it works fine so i dont care. ive heard of people wiring it to their alternator, which also makes sense but being the lazy person that i am, i went coil.
elaborate!
Getting rid of my electric choke and going full manual operation was the best decision I made that year....
elaborate!
elaborate!
Yeah, I'm intrigued to Gun
at the time it was more of stylistic choice, i just liked the way the curved looked better. but after i put it on, i was looking at it and thought "wow, good thing i didnt get a straight bar, it woulda run right into the dizzy" lol so lucky me
True, I had a straight one in my car and it ran right over the dizzy. I guess luckily I bent it a little putting it in. I had it cut out a couple months ago and I was going to go with a curved one when I buy another.
I though you would never ask
1) In the winter I had to dial in more choke to get good idle
Then dick with occasionally
2) In the summer i had to dial out some choke to get good idle
3) Once it warmed up I have to stomp on the gas to get out of choke position
4) Choke is set longer than it needs to be as I find a good place to stomp on the gas
**enter manual Choke***
1) Pull choke 50% turn key, back out of drive set choke zero % ...DONE effort 1%
2) In the middle of Jerkwater USA Low speed carb circuit becomes mostly blocked...Go oh **** as engine leans and dies...pull choke 75% start engine use choke to maintain mix at idle set zero for high speed repeat for low speed...escape from Jerkwater avoid jackers
Maybe it was my carb maybe a new auto choke would have fixed the problem I dont care I'll never go back to auto choke. I dont have to fight with the manual at all its the bees knees.
-Gun
-Gun
mrappe
09-26-2015 10:16 AM
uberstang1
09-20-2015 06:42 PM
TfcCDR
09-14-2015 12:08 PM
