Question for those with 65 disc brakes
I checked all the plumbing and it is correct. I have to still check the vacuum but I have a pretty mild cam( edelbrock performer) so I dont think that is the issue. I will check the vacuum this weekend. I just think that a 7 inch booster may not be really big enough. I will also try different(maybe a softer compound) pad later. I dont think that I can even lock up the brakes unless maybe using both feet.
Well after a whopping couple of hundred miles I have noticed that my disc brakes just aren't up to par. They require alot of pedal pressure to stop. I originally had 4 drum brakes which were converted to SSBC fronts and I have wilwood brakes on my 9 Inch rear.
Everything is new with a proportioning valve on rear. I thought that they just needed to be broken in but they just arent that good.
They have been bled( bench and regular) and pedal pressure is fine.
I read something from "Mustang Steve" about a pedal modification and am wondering if this would help. I have power brakes( I think 7 inch boster with 1 inch piston with dual master). Do you guys have good stopping power with a stock pedal. Let me know your thoughts
The only booster I would consider for a 64-66 is the original Bendix type. You can get them with single or modern dual master, and you can lock the wheels with your toe if you want to.
That master cylinder bowl is for front disc/rear drum. Disc brakes need a larger volume of fluid. However, in most applications it will work. I also don't think it is your vacuum. I would say the MC bore is too large and 15/16" would be better, but I would think SSBC would select the right bore for the application. Didn't you get a new distribution block with the upgrade? There is a good chance it is keeping fluid from the rear brakes. I would replace the block with either the correct one for a disc/disc application or use a tee for the front brakes and an adjustable pv for the rear.
I am running the stock distribution block with a proportioning valve( adjustable ) to the rear. I have the valve set in the middle by counting the number of turns. I know this is approximate but I havent been able to really lock it up to adjust where the rears come on.
The booster is from a kit I got from SSBC.
Try this: Find a smooth gravel drive or road. Stop with increasing pedal effort until you lock front or rear. Adjust until the front locks slightly before the rear. This is way less violent than doing it on asphalt.
That would be the lame booster I referred to. The one I posted, with dual master (which BTW has big enough reservior for disc or drum) would work far better.
musnicki
09-23-2015 07:11 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
