Noise coming from the rear of car
First off I have a 67 Mustang Coupe with a 289 auto. Question is....I have this noise coming from the rear of the car, like when I pull on to an uneven road or driveway. Sounds something like squeek/flex sound. When the car is parked I have pushed down on the rear bumper and I hear it a little....then lifting up I'll here it again. Could this be the shocks or the leaf springs? I took out the rear sway bar thinking the bushing were causing this...but it is still doing it. I also sprayed wd40 on the leaf-springs which have done nothing to stop these noises! I also took out the exuahst from headers back and the mufflers welded back on the reducers(just temp) and this has not stopped the squeeking... This is driving me crazy....any help would be much appreciated :-)
Its either the leaf spring or shock. Use some silicone spray on the leaf springs. Don't forget to spray the rubber bushings too. Have a feeling it is the rear shackle making the noise so spray the bushings there on the top and bottom. Good luck
91StangOwner
08-20-2015 11:34 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
