smoke is coming out of Oil Cap
Old 08-08-2009, 02:38 AM
Pavulon_
Pavulon_'s Avatar
Default smoke is coming out of Oil Cap
Hi all,
from time to time I see some smoke coming from engine through oil cap. Is this normal? I did change the oil cap (better one with gaskets) but it happens again. Any clues ?
Pavulon_ is offline
Old 08-08-2009, 07:47 AM
2+2GT
2+2GT's Avatar
Depends. If you have a PCV valve, make sure it's clean and operating properly.
2+2GT is offline
Old 08-08-2009, 11:09 AM
Pavulon_
Pavulon_'s Avatar
well, I just found out what pcv valve is and I don't think I have it, unless I don't know where to look
here's my engine bay
http://www.pawellewandowski.com/foty...ja5/silnik.jpg
Pavulon_ is offline
Old 08-08-2009, 12:00 PM
2+2GT
2+2GT's Avatar
The hose connected to the middle of the RH valve cover is the PCV hose, the metal thing inserted into the valve cover is the PCV valve.
2+2GT is offline
Old 08-08-2009, 01:20 PM
Pavulon_
Pavulon_'s Avatar
thanks, I'll check it then.
Pavulon_ is offline
Old 08-08-2009, 01:26 PM
Redwings
Redwings's Avatar
Good luck, I hope that fixes it for you.
Redwings is offline
Old 08-08-2009, 02:37 PM
Pavulon_
Pavulon_'s Avatar
well, it seems fine, I mean I blew it and the air goes through, I will check the hose that goes to intake I guess.
assuming the pcv valve works correctly is this something I should be worried about ?
Pavulon_ is offline
Old 08-08-2009, 03:05 PM
2+2GT
2+2GT's Avatar
See if the PCV is sucking air at idle. Just pull it out and feel the end while idling. It should grab pretty good. The spacer plate under the engine could be clogged, a long shot but I've seen it. Other, bad things, could be responsible.
2+2GT is offline
Old 08-11-2009, 02:54 PM
Pavulon_
Pavulon_'s Avatar
I did check it. It does grab, don't know how to determine if it's 'pretty good' but grabbed my finger
the smoke does not appear to often so I assume PCV doesn't work perfectly all the time, however I see a bit of oil around oil cap and dip stick, not much but still.
The oil pressure gauge most of the time indicates high pressure, not always, but most of the time. On cold engine it does so I guess smth is wrong.
Thanks for tips, any more ?
Pavulon_ is offline
Old 08-11-2009, 04:09 PM
kalli
kalli's Avatar
too much oil in the engine?
kalli is offline
Quick Reply: smoke is coming out of Oil Cap
