Brake Master Cylinder Question
I want to swap out my original single reservoir to a dual reservoir master cylinder. I have a 66 mustang with an inline 6, not sure that matters. What year could I use to bolt right in or with little modifications? Any help is appreciated. Thanks again everyone.
I have the same a 65 inline six, converting to a 5.0. I read that you could use a fox mc, not sure how much work it is since I still have mine waiting to finish the motor swap before starting with the mc. When I get home I'll post more info, have pages saved to my comp.
I used a MC like the 67 Mustangs had.
http://www.mustangsunlimited.com/ite...p?T1=F71248+01
If you are going to go upgrade the brake system why not upgrade the front to disc and do a Granada or similar swap.
I have seen people use the Fox style MC too. I think fakesnakes has one.
Thanks tx65coupe and guybored. Looks like it might be an easy swap.
I'm eventually going to upgrade to the front disc brakes from here
http://www.discbrakeswap.com/Mustang...20CATALOG.html
Until then, I wanted to give the current brakes a little bit of an upgrade. Thanks again you guys.
http://www.cjponyparts.com/NewTechDualMC.aspx
The kit from CJ is actually what I have on my car. The MC looks like that 67 one and not like the one pictured.
Its on page 62 of CJ's catalog.
The MC I got when I bought DBC4 had a dual bowl MC that looked like both bowls were equal size. The MC I got looks like the 67 MC where the front bowl for the rear brakes is smaller. I'm not sure why the picture is different.
Thanks again everyone. I appreciate the instructions from CJ pony, this is going to be my next little project, changing the MC, spring kits and wheel cylinders. The car has been sitting for a while and I want to handle the brakes first and foremost. Thanks again everyone, always a reliable source.
Luke9222
10-22-2015 11:55 PM
