4 to 5 gear conversion 1967 Fstb 390 GT
Old 08-19-2009, 09:30 AM
K-Arts
K-Arts's Avatar
Default 4 to 5 gear conversion 1967 Fstb 390 GT
Hi all,
i was wondering which the most uncomlicated way would be, to convert the 4 speed to a 5 speed. Maybe a T-5 Tremec?
thx for all input!
Michael
K-Arts is offline
Old 08-19-2009, 09:49 AM
K-Arts
K-Arts's Avatar
i checked the FAQ, but i only found Auto to T5 conversions.
Is it then the easiest thing to change from toploader-4 to T5?
thx
K-Arts is offline
Old 08-19-2009, 09:50 AM
TexasAxMan
TexasAxMan's Avatar
T-5. All you would need would be a fulcrum spacer (if you use the T-5 bell) and a crossmember. You might have to shorten the driveshaft as well.
If you want to use your existing bell, you'll need the adapter.
Check out the link below, it pretty much explains it all.
http://www.sacramento-mustang.com/Ne.../t5_swap.shtml
TexasAxMan is offline
Old 08-19-2009, 10:06 AM
Norm Peterson
Norm Peterson's Avatar
Might want something a bit stouter than a T-5 if you've still got a 390 under the hood.
Norm
Norm Peterson is offline
Old 08-19-2009, 10:33 AM
Starfury
Starfury's Avatar
I agree. Even the T5z is only rated to 330ft-lbs, which is very easy to exceed with a big block.
If you're set on a 5sp, I'd start looking at TKO's.
Starfury is offline
Old 08-19-2009, 12:19 PM
1965screamer
1965screamer's Avatar
What about G-force internals? They can handle some power and probly a little cheaper then a TKO.
1965screamer is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: 4 to 5 gear conversion 1967 Fstb 390 GT
