351c FMX tranny questions
Old 08-28-2009, 08:47 AM
dbgrigsby93
dbgrigsby93's Avatar
Default 351c FMX tranny questions
I'm going to be changing out the 2v heads for 4v heads sometime in the near future on my '73 mach 1 and after reading a thread about FMX trannies I'm being lea to believe that the 351c 2v had the FMX but the 351c 4v had something else. Is that true? What transmission did they put behind the 351c 4v and will my FMX transmission be okay if I put cast iron 4v heads on my 351c?? I'm only planning to get about 350hp. I'm going for a street cruiser with some xtra power, but I don't want to change my tranny. Will the FMX be okay if I make this conversion?
dbgrigsby93 is offline
Old 08-28-2009, 12:18 PM
4reboy
4reboy's Avatar
Yes the FMX should be good with that power, they can take a LOT. And if you don't have the FMX the only other thing that should be behind there is a C6, on the 71-73's I believe they put C6's and FMX's on the 351 engines, but not sure.
4reboy is offline
Old 08-28-2009, 03:06 PM
1971mach1
1971mach1's Avatar
My 71 with a 351C-4v origionally came with a C6.
I have heard the c6 is stronger than the FMX. Not to say the FMX is weak though.
They're both pretty heavy (weight) trannys though.
My car sure feels lighter now with the TKO 5-speed in it.
If you want to replace the FMX with another auto, you can get a beefed up C4 now, alot lighter too.
Personally, I'd wait until the FMX has problems though, unless you just have to shave off about 100lbs weight.
1971mach1 is offline
Old 08-28-2009, 03:08 PM
orange88
orange88's Avatar
I have an originally 351-2v with a swapped intake for 4v carb and the fmx works just fine
orange88 is offline
Old 08-28-2009, 04:11 PM
THUMPIN455
THUMPIN455's Avatar
Like said above, the FMX will work for you, a C4 will take a relatively stock Cleveland with a few upgrades, its an easy job for an FMX or a C6. Finding the C6 will take more effort and they soak up more power, but they are out there if you want one.
THUMPIN455 is offline
chrisdbassplayer
10-13-2015 06:53 PM
treesloth
09-28-2015 07:03 AM
2poor4u2
09-26-2015 11:08 AM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: 351c FMX tranny questions
