71 C6 Linkage
Old 08-29-2009, 10:10 PM
bw71mach1
bw71mach1's Avatar
Default 71 C6 Linkage
1971 Mach 1 w/ C6. The shifter has a lot of play in it. The linkage coming off the transmission has a lot of play. Where can I get these replacement parts? I've looked at alot of websites but don't see what I'm looking for.
bw71mach1 is offline
Old 08-29-2009, 11:04 PM
Sxynerd
Sxynerd's Avatar
LMR has lots of small parts like that. YearOne, also.
Sxynerd is offline
Old 08-29-2009, 11:39 PM
hiboostwoody
hiboostwoody's Avatar
National Parts Depot may also have what you are looking for.
hiboostwoody is offline
Old 08-30-2009, 05:23 PM
Flash70
Flash70's Avatar
You can also just measure the amount of play you think you have and purchase some bushings at the local hardware store. That is for the connection under the car from the shifter linkage to the shifter and from the transmission to the shifter linkage as well. That is what I did. Now if you have play at the shifter with it moving around a bunch that might not be anything under the car. I had this problem and to fix it I purchased rubber bushings after just guessing how much space of play there was and cut a slit on one part of the bushing and pushed it onto the rod that goes from the shifter to the pan and fixed up that space fast. It does not move around at all anymore.
Flash70 is offline
CMcNam
10-30-2022 11:40 PM
89lx302
05-26-2005 02:16 PM
snakebitdave
04-15-2005 07:04 PM
Bowdy04
12
01-05-2005 12:31 AM
SpeedRicer
02-10-2004 11:58 PM
Quick Reply: 71 C6 Linkage
