Carb choice.......which one for the set up I have??
In my 67, I have a 289 with a hydraulic flat tappet cam, performer rpm heads, headers and dual Magnaflow exhaust (by previous owner). I will be replacing the distributor and go with an electronic ignition. I have T5 and will be installing either 3.55 or 3.80 gears.
I'm using the car as a weekend cruiser and a trip to the strip occasionally.
Now, for my selection in carbs, I'm thinking of one of the following:
Holly Street Avenger - 570 cfm or 670 cfm??
OR
Barry Grant Road Demon - 525 cfm or 625 cfm??
What do you guys think with the setup I have/will have?
OR
I'm very pleased with the Edelbrock Performer 750 (note that I have a 351C-4v,
for a 289, you might want the 600cfm).
It worked great right out of the box. Reliable with no adjustments for almost 3 years (weekend driver). Drivability is almost as good as EFI. Edel says it's compatible with modern gas, so you don't have to rebuild it every year.
I have heard good things about both makers. I run a Holley on my car and I would also consider a Demon. I am not a fan of Edelbrock carbs (JMO).
If you go with the Holley, I would go with the Street Avenger - 570 cfm.
If you go with the Barry Grant, I would go with the Road Demon - 625 cfm.
only comes up to just shy of 600 cfm, so it doesn't see a lot of performance use.
