Would I notice a big difference with GT40 heads?
Old 09-10-2009, 12:05 PM
  #21
rmodel65
Yukon Cornelius
rmodel65's Avatar
e7's suck the cack :P they arent good only are a little better than a 289/302 head
rmodel65 is offline
Old 09-10-2009, 01:16 PM
  #22
my77stang
my77stang's Avatar
for 1200 if you have the cash i'd pick up the AFR's with the beehive springs.
my77stang is offline
Old 09-10-2009, 01:33 PM
  #23
USMCrebel
Mach I Section Moderator
USMCrebel's Avatar
if your putting money in them...look for some procomps and work them over...
For the price of the worked over 40's you can have a set of 185/210's... that's bang for your buck
point of reference look in the new MMFF they put 1k into a 302 and made 400hp...that's machining, parts, and labor....October 2009 issue, Vol 22 No 10.
USMCrebel is offline
Old 09-10-2009, 03:43 PM
  #24
my77stang
my77stang's Avatar
procomp's are crap castings though, i'd be leary of them cracking, warping, dropping a guide or seat, etc etc.
Old 09-10-2009, 04:32 PM
  #25
scootchu
scootchu's Avatar
I just came back from taking a look at a EFI 302 and came home with a 302 roller block. It had issues with the crank, but didn't spin a bearing. It was $25 so not a lot invested.
He had the 351 heads, but after listening to discussions about the money needed to get them to where they would make a difference I decided to pass.
I will call the other person about the GT40's.
scootchu is offline
Old 09-10-2009, 05:33 PM
  #26
LynnBob Mustang
LynnBob Mustang's Avatar
Do most places have headers for the GT 40 and GT 40P heads for a '65 auto, or is that going to be a hard/odd ball item to get?
Basically which heads are the least PITA to get headers for and have the least fitment problems?
Lynn
LynnBob Mustang is offline
Old 09-10-2009, 10:05 PM
  #27
USMCrebel
USMCrebel's Avatar
they've fixed that problem according to MMFF and several other 5.0 guys around here.
Old 09-11-2009, 01:23 AM
  #28
my77stang
my77stang's Avatar
hmm..... i think i'd rather take a set of patriots and have them warmed over with a little machine work.
Old 09-11-2009, 06:54 PM
  #29
scootchu
scootchu's Avatar
Picked up the GT40 heads with new head gaskets for $195 today and in the process a Blue Point engine stand for $35. Heads are complete and in good shape. The seller has oodles of Ford small block parts and said he would help me out when I got going on my engine build.
scootchu is offline
Old 09-11-2009, 10:46 PM
  #30
my77stang
my77stang's Avatar
sounds good! now strip them down, do some careful port work with a dremel or die grinder under the heads of the valves, drop them off at your local machine shop and have a valve job and resurface. thats when you should go ahead and put some stiffer springs and screw-in studs and guideplates too.
Luke9222
10-22-2015 11:55 PM
Pyrate Dave
09-10-2015 07:30 PM
tmdm
09-04-2015 06:45 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Would I notice a big difference with GT40 heads?
