Wheels and Ride Height - Page 5 - MustangForums.com
Old 01-10-2010, 12:41 AM   #41
itsa65
BA Mustang, very cool wheels.
Sorry to ask such a basic question, but everyone on this thread seems to have gone for the Shelby drop. Just picked up a very stock '65 "C" code and would really like some handling. Am changing wheels and tires, but is the "drop" a good choice for this street/ stock set up?
Can I do the drill myself, or is this an exact science needing specific engineering? Will stock/repro upper control arms bolt right into this drilled mod, or do I need to go to tubes?
Do I need to go to a shorter/GT spring, or can I use the stock springs?
Any info much appreciated! Thanks, guys.
itsa65 is offline   Reply With Quote
Old 01-18-2010, 10:49 AM   #42
1slow67
ROTM Moderator
1slow67's Avatar
It definitely helps out a bunch and I use it on the street. They have a metal template out that you use to mark the spots to drill. Stock arms work fine with this, that is what most if not all of us are using. Stock springs work fine I was running them until I decided to upgrade to the 1" drop coils when I was beefing up the front.
This site is helpful. http://dazed.home.bresnan.net/drop
1slow67 is offline   Reply With Quote
Old 01-19-2010, 06:52 PM   #43
resale red
Great looking cars! I have a 69 mach 1 with stock 14 inch wheels and want to know if I can go with 275s? I was told 245 is the max width without modifications?
resale red is offline   Reply With Quote
Old 01-23-2010, 09:34 PM   #44
1slow67
ROTM Moderator
1slow67's Avatar
You should be able to run those on the rears. Fronts I wouldn't go more than 245.
Old 01-27-2010, 02:13 PM   #45
mySAVIOReigns
Perhaps you wheel afficianados can assist me. These are the wheels I'd like to put on my Mustang, once I get to it. I put them on for a mock picture and I think they look pretty good, but I have no idea what kind of wheels they are
They're 15x7 (all four), and the tires are 205/50R15. I love the tires but I can't find them locally, from BFG. I have no stats on the ride height and springs, because all of that isn't installed yet
I can't find any brand on the wheels. All it has "engraved" on it is "15 x 7"
Any ideas?
mySAVIOReigns is offline   Reply With Quote
Old 01-27-2010, 02:26 PM   #46
1slow67
ROTM Moderator
1slow67's Avatar
Looks like an old drag wheel.
Old 01-27-2010, 03:02 PM   #47
Norm Peterson
Norm Peterson's Avatar
Quote:
205/50-15 is a bit light size-wise for a 3000# car, and will look a little small in the wheelwells once you get it all together. I'd look at least up to 205/55 or perhaps 205/60. I think 205/60-15 is the closest diameter to the OE tires at about 24.7" OD.
Point of reference - one of my cars is a 1995 Mazda 626, about 2900 lbs with an OE tire size of 205/55-15 (on 15x6's). I do run extra-capacity competition tires in 205/50-15 on 15x7's at autocross that are good for the same load, but the gap between the tire OD and the wheel well is pretty big when I've got them mounted up. With the suspension compressed to the bump stops, there's still an inch or so gap.
Norm
Norm Peterson is offline   Reply With Quote
Old 01-27-2010, 05:07 PM   #48
boogerschnot
boogerschnot's Avatar
This is mine with the 245 45's up front and 255 45s in the rear. Still with mide eyes and spacers.. 1.5 inch spacers up front and 1.25 in the rear. 17x8 ford wheels.
boogerschnot is offline   Reply With Quote
Old 01-27-2010, 10:09 PM   #49
oldrock
oldrock's Avatar
the 275 tires will fit in a 69 but that is about the max if you want to still keep it mostly under the wells. I went with 275s on back of mine on a 15x8 rim and 225s up front on a 15x7 rim.
what 275 look like on a 69 coupe
pic from the side
oldrock is offline   Reply With Quote
Old 01-29-2010, 11:07 AM   #50
ventagemod67
ventagemod67's Avatar
here is mine..
cut stock springs 1 1/2 coil.. had performance drop springs but didnt drop it
1" lowering leafs for the rear
1" front sway bar.. 1/2" rear sway bar
17x8 wheels 225/45/17 tires up front
17x9 wheels 245/40/17 tires on the rear.
ventagemod67 is offline   Reply With Quote
Meet Denise, My *New* 2015 Mustang GT Premium (Pics and Videos) JoshyGT The New S550 2015-2016 Mustang 15 12-18-2015 10:14 AM
Help Lowering a 14 V6 Vert robcy Suspension 1 10-28-2015 12:14 AM
2000 Cobra R front bumper Sparks_88 4.6L (1996-2004 Modular) Mustang 0 09-08-2015 02:06 PM
Happy with new Steeda suspension on my 2010 GT robjh22 Suspension 0 09-08-2015 01:47 PM
Loud Noise Above 30 MPH bjdutch2005 2005-2014 Mustangs 8 09-07-2015 11:05 PM
17, 1965, 1967, backspacing, drop, gt, height, heights, inch, mustang, ride, shelby, size, stock, tech, wheel, wheels
