Fog Lights in a 1966
I bought a scott drake fog light kit-have some wiring problems
It came with direction but I am lost.
behind the instrument panel near the headlight switch i was suppose to find a 3 prong connector...seperate it and plug the ends into the connector of the new wiring kit.
I dont have this connector
The directions state that some 1966 cars have the 1965 old 2 prong connector...I THINK this is what I have.
the connector is yellow plastic with black wire on one side ...and on the other is red/black wire,a green with another green with a open female plug coming off, and last but not least is a empty female hole.
is this the 2 prong version....can some on tell me how to hook the scott drake wiring kit into this?
also where should I tap into for the power...the power lead has a male end ...is there a open female connector for easy power?
I am lost.....Thanks Scott
There is also a wire kit that goes from the firewall plug to the lamps, and includes the ground wires for the lamps.
Did they at least sell you the radiator support grommets?
Here is a link to a Mustang Monthly article on the subject. http://www.mustangmonthly.com/techar...hts/index.html And a diagram for the wiring. http://www.kkpony.com/images/66exter...ng-diagram.jpg
The diagram has a wire connected to the starter relay battery terminal and then through a circuit breaker to get power. I would use a pigtail and connect it to the center terminal of the ignition switch. If you don't have the circuit breaker you should get one. It is needed. The only other wire that hooks up to the existing wiring is the black wire the should hook to an empty female connecter coming off of the light switch. You only need to hook that up if you want the tail lights to come on with the fog lights. I would hook it up because it is a nice to have thing. I have done a few 67 which are just about the same as 66's on the fogs and they were fairly easy. If you have more questions come back.
The kit shown in your first link shows the proper kit I referred to. Everything you need to do a factory correct job is in there, and it's not even expensive.
The main stud on the back of the ignition switch is hot all the time and I'm pretty sure that is were the schematic had me wire it up on the last 67 I did. I don't remember going all the way out to the starter solenoid to get power like the 66 Schematic says to.
Holy cripes! You don't "have to go all the way to the starter solenoid". Ford didn't. There is a large yellow wire bundled in the main harness behind the speedo. Ford tapped into that. The gray wire in the above photo is in case you have a non-fog harness, lacking the gray. The Scotchlock attaches it to the yellow wire.
You are reading that schematic too literally- the wire doesn't go the the solenoid, the circuit does. The gray wire only goes to the yellow wire under the dash, the yellow wire goes to the solenoid.
Also, You don't have to connect that one wire to the tail light circuit. I didn't when I put the same type of kit on my 65. Its to turn on the tail lights when you turn the fog lights on. I don't see the point of it, because if you have the fogs on you would have the parking lights or head lights on anyway.
Also, If you don't want to drill a hole in your dash for the switch you can do what I did an put it on the bottom of the dash. There is a hole the correct size a few inches in on the far left side.
Question about original style fog light harness wiring
I've got a 66 mustang and gave added fog lights. It's got a reproduction original style wiring harness. I've got the lights hooked up to the harness that feeds through the firewall, hooking up to the switch itself. My problem is that I've got a painless performance harness. Their tech people are telling me to use the accessory relay portion of the harness to wire the fog lights. Anybody ever wired the fog light harness up to the painless performance harness? And how did you do it? I'm not a wiring expert so a little direct would help a lot. Thanks
