Our '65 coupe project, so it begins (Lots of pics)
#102
Success! After much messing around and fitting I got the torque box finally in! Too bad I ran out of welding wire 1/3rd way through welding it up. LOL!!
I can't find a store open around here that has welding wire and the ones that were didn't have .24 wire, oh well I started fitting the other side. The whole key is to separate them as others have stated, it saves a lot of headaches.
Lynn
Lynn
Also note that the gas coming from welding galvanized is toxic. You may have noticed a sweet smell when you were welding that area. That is you poisoning yourself. This is another reason I do 1" at a time. I basically hold my breath and step away before taking another.
#103
I made sure when I cleaned the metal before I welded it that it was sparking really good with my grinder. The guy that showed me how to weld said that the metal will spark when hit with a grinder once the galv coating is gone. It will not spark with the grinder when it is still on.
A friend that welds on Navy ships told me to have milk on hand and drink a big glass when done welding the frame as the milk counteracts any toxins from any galv. poisoning. That was one of the things they were taught while in the Navy learning to weld.
I looked at the pic and I remembered those bigger welds were me missing the seam and having to redo some of it. I was a little off track and a couple spots I missed altogether, so I had to redo them.
I will try and weld the other TB as you mentioned when I do the other side.
Thanks,
Lynn
Thanks,
Lynn
#106
I got the frame rail tips fixed and the trunk drop offs test fit and the same with the trunk brace.
The frame rail tips don't look too pretty on one side as It is hard to get in the cramped space with the welder, but I beat the **** out of them with a hammer and they didn't come apart, so I guess I did OK on them.
Ahhhh, more new METAL!! LOL!!!
Lynn
Lynn
#107
Wow great job. I did a lot, or so I though with my car, but I don't think I could successfully go this far. Outstanding and great to see. Thanks for sharing all the pics.
I'm going to have a glass of milk now
#108
LOL!! Thanks!! Have a drink for me as well, I'm tired.
I never once thought I would/could ever get this far, but this car is for my wife. I really don't want to let her down with it. That is my drive and push to get her done.
Lynn
Lynn
#109
I got the trunk brace and trunk drop offs welded in place.
I just gotta patch a couple spots on the trunk floor edge where I ripped up the floor getting the brace out. I'm almost out of gas for the welder, so I gotta get some more.
I test fit tail light panel again and it looks good.
Lynn
Lynn
