Purchased 65 Mustang. Few questions.
Sorry you are right I pulled that off google and that is the right side and those are the cooler lines. On the driver side there seems to be a similar fitting and tube that comes down like that.
you can also make your own for im sure a lot cheaper. i made mine ( for a powerglide but im sure you can do it for a c4 as well) out of tubing with the fittings from advance auto, napa also sells the stuff. its the " brake line" as they call it although i dont know what car that size break like would fit. lol. just some patience, strength, and i did it for like 10 bucks and about 45 min.
I found out it is an overflow port for when there is too much fluid in the trans. I guess since the cooler is bypassed the trans got hot and built up pressure to reach that port and overflow. When I started the engine and checked the fluid it was very high on the dipstick. Transmission shifts good though so I dont believe anything was damaged. I dont really know what the previous owner was thinking..
10-01-2015 05:13 PM
treesloth
09-28-2015 07:03 AM
