help choosing heads
Old 11-17-2009, 01:16 AM
MonsterBilly
MonsterBilly's Avatar
Default help choosing heads
I am tired of having issues with my worked over factory heads. It is time that i just get new heads that will deliver the goods. i have read a lot and i am more confused than ever.
Here is what i am running now to the best of my knowlege.
-670 street avenger
-Lunati Camshaft, Hydraulic Flat Tappet, Advertised Duration 268/276 Lift 522/.538, Ford, Small Block, Each
-Wiend Stealth intake
-All ARP hardware
-bottom end completely balanced
-Hyper pistons (not sure the brand but i know it was quality stuff
-high flow oil pump
-hardend push rods
-comp cams magnum roller rockers
Should i go with the AFR heads or the Trick Flow heads? Also are the Edelbrock heads a good choice.
I want to squeeze as much out of this as i can get.
MonsterBilly is offline
Old 11-17-2009, 02:28 AM
MonsterBilly
Im thinking about these
http://www.summitracing.com/parts/TFS-51400004/
or these
http://www.summitracing.com/parts/FMS-M-6049-X306/
Old 11-17-2009, 05:27 AM
kalli
kalli's Avatar
Originally Posted by MonsterBilly
http://www.summitracing.com/parts/TFS-51400004 are desgned for hydraulic roller.
http://www.summitracing.com/parts/TFS-51400002 is for flat tappet
If I were in your position I'd clearly go for those (depending).
Kalli
kalli is offline
Old 11-17-2009, 09:52 AM
Starfury
Starfury's Avatar
Don't bother with those GT40X heads. They're better than factory heads, but you can pick up a set of something much better for a couple hundred more.
I just put a set of Trick Flows on my 331 and I love them. The twisted wedge design ensures that you won't have to worry about valve/piston interference, and it also unshrouds the valves for better flow rates across the board.
If you're interested in a pair, PM me. I can send you to someone who will probably give you a better deal than Summit
Starfury is offline
Old 11-17-2009, 11:15 AM
sixt5
sixt5's Avatar
afr 165 or a trick flow is top notch for your cubes. im going afr 185 for my 347
sixt5 is offline
Old 11-17-2009, 11:21 AM
urban_cowboy
urban_cowboy's Avatar
Love the performance of the AFR heads. They are second to none, but the quality of their valves is junk. If you have the money, get CNC AFR heads (blank). Then get some good hardware like valves like Ferrea, ARP studs, and match your springs to the type of lifters and cam you get. Many people do not have problems with stock AFR stuff, but their hardware did not hold up in my engine.
urban_cowboy is offline
Old 11-17-2009, 04:18 PM
MonsterBilly
Im going with the trick Flow Heads. I sent Starfury the PM he requested.
I am ready to do a ton of mods in the next two weeks. I am getting the 8.8 buttoned up and installed. I am converting over to the 13in cobra breaks. (ive bought all the stuff just need to install it) and i am going for the heads. I cant wait to rip **** up! ughh get some!
Old 11-18-2009, 06:37 AM
kalli
kalli's Avatar
that sounds like a great plan. the T5 is able to just handle that power, just don't do any powershifting!
kalli is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
mustangheaven
10-07-2015 10:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: help choosing heads
