oh wait you need to use the hubs.... well you just need to remove the hub and drum and get them pressed out....my disc kit i removed everything at once and junked the rest....
Remove the hub and drum as one assembly by removing the spindle nut and outter bearing. Once you have both the hub and drum of you can assess if the drums need replacing. If you then need to get the drums off the hubs either use a brass punch or put an old nut on the stud to knock the studs out of the hubs using a big hammer. The studs are the main thing that keep the hub and drum tgether.
