69 Alcapuco Blue
I have thought about putting thew Magnum 500 rims on the car. Will the 15 inch rims make the speedometer read off. It has 14 inch rims on it now. But then again everything on it is stock so I kinda want to leave the wheels origional too.
Good wheel choice. The speedometer shouldn't be off unless you run taller tires. If you run something like a 215 60 15, you should be fine. You can always change the speedo gear if need be. They are only a few bucks.
breaking
10-02-2015 01:27 PM
