65 side molding trim
Old 01-25-2010, 11:02 AM
chewy1234
chewy1234's Avatar
Cool 65 side molding trim
Any tips on removing the side molding on the lower rocker panel area on a 65 Fastback. I removed the screws and it will not slide or pull off. It is the chrome piece that has black stripes in it. Thanks.
chewy1234 is offline
Old 01-25-2010, 11:42 AM
jspagna1
jspagna1's Avatar
After you have removed the screws front & back, you can use a screwdriver with a towel wrapped around the end of it so you don't scratch the paint and wedge it between the body and the molding. It should pop right off. Again take your time & be careful.
jspagna1 is offline
Old 01-25-2010, 12:11 PM
2+2GT
2+2GT's Avatar
If you press downward on the moulding, you should be able to unhook the bottom edge without tools.
2+2GT is offline
Old 01-25-2010, 01:28 PM
chewy1234
chewy1234's Avatar
I thought it slides off. Looks like it pulls or pops off. I will give it a try.
chrisdbassplayer
10-13-2015 06:53 PM
b8checker
10-08-2015 12:55 PM
ChampInSD
10-02-2015 04:55 AM
mdg
10-01-2015 07:04 AM
b8checker
09-30-2015 07:11 AM
Quick Reply: 65 side molding trim
