Brakes went out and I can't find the problem
Old 03-06-2010, 02:41 PM
  #21
rtintwo
rtintwo's Avatar
Your seitch shouldnt have any fluid on it. Replace the seals in the distribution block shuttle.
rtintwo is offline
Old 03-06-2010, 02:57 PM
  #22
RogerDodger1
RogerDodger1's Avatar
Originally Posted by 67t5ponycoupe
It is a shot in the dark when everyone is advising him to replace the master cylinder without inspecting the system. That is the shot in the dark I'm talking about. I do agree that the master is most likely the problem but you can't conclude that without a system inspection.
Agreed 100%. A car should be diagnosed, not just have parts thrown at it hoping it will fix the problem.
RogerDodger1 is offline
Old 03-06-2010, 05:03 PM
  #23
oldrock
oldrock's Avatar
if you are still running the original mc on a 67, I'd say change it either way. Brakes are one component where it is much better to change things BEFORE they fail on you. I had same issue with my 69 mustang ie. hard to stop had to pump brakes and didn't have any leaks I could find. Changed mine over to power discs up front and man is it ever nicer. Was not a simple job by any means but now that I have it done and installed I am sure glad I did. Car stops so much easier now and doesn't require alot of foot pressure at stop lights anymore!
oldrock is offline
ShaneB26154
09-06-2015 08:13 AM
stormesixx
08-25-2015 09:11 AM
FD725
08-23-2015 06:43 AM
dba Brakes
08-20-2015 11:03 PM
cvarner131
08-17-2015 07:38 AM
Quick Reply: Brakes went out and I can't find the problem
