302/3spd manual flywheel question
Old 02-04-2010, 06:51 PM
67BullittCoupe
67BullittCoupe's Avatar
Default 302/3spd manual flywheel question
hey guys. i got the transmission out and im about to take out the clutch on the coupe. any thing i should know before i take everything apart to take off the flywheel?
67BullittCoupe is offline
Old 02-05-2010, 05:16 AM
kalli
kalli's Avatar
you'll need an alignment dowel for putting it back in (plastic copy of input shaft). you can use a cut input shaft of a scrap transmission as well if you have one. Other than that I couldn't think of anything
kalli is offline
Old 02-05-2010, 10:16 AM
MBDiagMan
MBDiagMan's Avatar
Also when re installing the flywheel, tap the bolt holes first and then use some loctite on the bolts and torque them to spec. in a cross pattern.
Don't forget to check the pilot bushing while it's all apart.
MBDiagMan is offline
Old 02-05-2010, 11:48 AM
urban_cowboy
urban_cowboy's Avatar
And if you replace the clutch, you should have the flywheel surface machined.
urban_cowboy is offline
Old 02-07-2010, 12:43 PM
67BullittCoupe
thanks, not replacing the clutch. just installing a new ring gear.
sounds good. thanks.
dudeguy421
09-24-2015 11:16 AM
04stangman
09-17-2015 01:45 PM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: 302/3spd manual flywheel question
