Hooking fused wires straight to the battery versus solenoid?
Is there any difference in this? I have too many wires on my solenoid and wont be able to screw the nut down so If I connect them straight to the positive terminal on the battery will it make a difference?
The wires I want to connect straight to the battery will be headlight power (from relay), electric fan power (from relay), and radio amplifier (fused 8 gauge)
Anything wrong with this?
Hmmm whats connected to the solenoid is the electric fan, headlight relays, radio amp, alternator, and the battery cable which is 0 gauge so its really thick connection
The reason I am going to run out of room is because I was going to get a mini starter and it has me move the starter cable over to the power side of the solenoid and I already don't have any room to add anything else.
Any Mustang supplier is likely to have both.
Summit has a bunch of junction blocks, Jegs and most others will as well. Getting the connections off the battery will limit the corrosion issues and clean up the under hood wiring. You can also get junction blocks off newer cars in the junkyard, quite a few that have the battery buried under air boxes and other stuff will have a junction block as a power source to jump the car or test the battery.
http://www.summitracing.com/search/D...s/?Ns=Rank|Asc
I forgot about that OE style one 2+2 is showing. I was thinking about one more like what Thumpin linked to. Either will work though. I was thinking about putting one on my car. Right now I am at the point to where I can't add anything else to the solenoid either. I don't plan on adding much if anything else, but the need may arise when I do need to.
