torque specs
torque specs
hey guys im having some trouble finding the torque specs for the rear end of my 69 mustang. i need the following...
U-bolts that tie down the diff. to the leaf springs
small u-bolts on the drive shaft
leaf spring bolt.
leaf spring shackle bolts
and the rear shocks.
i need to know what to torque them to. any info would be much appreciated.
thank you
leaf spring bolt.
thank you
U-bolts that tie down the diff. to the leaf springs 30-45
small u-bolts on the drive shaft 12-15
leaf spring bolt. The bolt holding the leaves together? Not mentioned, an not crucial either
leaf spring shackle bolts 15-22
and the rear shocks. 15-25 for both upper bolts and lower bolt
thank you
thank you
All measurements are ft*lbf
Whenever in doubt just look it up online. You can find generic torque spec guides for the size/thread pitch of everything. It's the same. Just makes sure you use the spec of the SHAFT size and NOT the socket size.
LivingInThePast
09-16-2015 12:20 PM
