Trouble starting up when car is warm n driven - Page 2 - MustangForums.com
Old 03-18-2010, 01:15 PM   #11
Gun Jam
Moderator
Gun Jam's Avatar
which brand was it?
You could try a mini starter which may indeed solve the problem but like I said its not always sunshine and bunnies with mini starters
You could try to find a better brand of stock stater...if that's even possible
Why did you replace the old starter?
-Gun
Gun Jam is offline   Reply With Quote
Old 03-18-2010, 01:38 PM   #12
Vikefan88
Vikefan88's Avatar
I'm sure it's like duralast, the old one just went out on completly. Ur right because u still have the problem. I'm a try to order n see though.
Vikefan88 is offline   Reply With Quote
Old 03-18-2010, 02:01 PM   #13
Gun Jam
Moderator
Gun Jam's Avatar
I cant blame the mini starter concept which is actually logical n will probably work for you. Im pretty sure my connections are all good n it works most of the time so i live with it, maybe its just a bad egg. I never had any issues with my stock starter . The mini starter I got from NAPA so I would think it would be fairly decent especially for that price I payed for it.
let us know if the 55 buck mini (or whichever one you go with) solves your problems.
-Gun
Old 03-18-2010, 02:04 PM   #14
71Mach14spd
They sell what i call a "bag" that goes over the starter and it acts as a heat shield and keep the header heat from over heating the starter. Don't rap the headers though otherwise they will rust.
71Mach14spd is offline   Reply With Quote
Old 03-18-2010, 02:09 PM   #15
Vikefan88
Vikefan88's Avatar
Can I get that shield for the starter locally at a auto parts store, I'm a try that n adjust the timing first.
Old 03-18-2010, 02:14 PM   #16
eZ
eZ's Avatar
whats the compression on your 347? I would think a stock starter would have a little harder time turning it over if you went 10:1 or higher.
To highjack this thread a lil I switched to a high torque mini starter and after the car fires the starter is still turning for a second. does not sound good but I cant find the fix?
eZ is offline   Reply With Quote
Old 03-18-2010, 02:23 PM   #17
71Mach14spd
Quote:
I would think so, if you can't find it at a parts store any mustang shop or performance shop should have them.
Old 03-18-2010, 02:25 PM   #18
Gun Jam
Moderator
Gun Jam's Avatar
Autozoo has them, Kragan n pep boys too.
Old 03-18-2010, 02:30 PM   #19
MBDiagMan
MBDiagMan's Avatar
You need to do or have done a voltage drop test to determine the source of the trouble.
MBDiagMan is offline   Reply With Quote
Old 03-18-2010, 02:47 PM   #20
Vikefan88
Vikefan88's Avatar
How or where
Sputtering low RPM when engine warms ShaneB26154 4.6L (1996-2004 Modular) Mustang 34 05-15-2016 10:30 AM
03 GT Chirping on Throttle msavoia23 4.6L (1996-2004 Modular) Mustang 11 08-21-2015 12:05 PM
Groaning noise coming from rear when turning right 92 5.0stang 5.0L (1979-1995) Mustang 4 08-13-2015 07:46 AM
FORD FRENZY!!! Milan Dragway-September 12th Milan Dragway Members Rides and Car Show Section 0 08-12-2015 04:43 PM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 01:59 PM
1965, 99, car, carburetor, classic, cold, gt, hot, lag, mustang, start, starting, starts, trouble, v6, warm
