convertible top fluid
Old 03-24-2010, 09:07 AM
noroof66
noroof66's Avatar
If you have been working on the car without charging the battery, you most likely drained it. I bet you did not burn the motor, just not enough power to it.
noroof66 is offline
Old 03-30-2010, 08:37 AM
blue289
blue289's Avatar
I charged the battery and rechecked the ground and the motor works. However the top is still not moving. Again, I run the top motor for a while and then the fluid stops moving. Could this be an electrical issue and draining the battery because the car is not running?
blue289 is offline
Old 03-31-2010, 02:07 PM
2+2GT
2+2GT's Avatar
Some. The battery is 12V, while the alternator should be providing 14V with the engine running. Running the top motor with the engine off is normal, though, it should work fine that way.
2+2GT is offline
GPR
12-16-2015 12:21 PM
LivingInThePast
09-16-2015 12:20 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: convertible top fluid
