Whistle coming from motor
Old 04-11-2010, 07:58 AM
abandel
abandel's Avatar
Default Whistle coming from motor
When my 67 coupe heats up I get a whistle noise coming from the motor. I used an auto stethoscope and the only place that sounds different and where I can hear the whistle is at the carb. I checked all the hoses and do not see any air leaks. Could it be something internal in the carb? I have a Holley 4-barrel.
abandel is offline
Old 04-11-2010, 12:32 PM
Gun Jam
Moderator
Gun Jam's Avatar
when did it start doing this?
does it run exactly the same as it did before it made the noise?
Does it do it at high rpm or low rpm or all the time?
-Gun
Gun Jam is offline
Old 04-11-2010, 03:30 PM
abandel
abandel's Avatar
Not sure exactly when it started but it runs the same. The whistle is at any RPM.
abandel is offline
Old 04-11-2010, 03:37 PM
longlive289s
longlive289s's Avatar
any possible way to take a vid of it whistling? only thing that i can think of whistling would be the vac advance but i dont think it has enough pressure to actually make a whistle sound
longlive289s is offline
Old 04-11-2010, 03:53 PM
71Mach14spd
71Mach14spd's Avatar
Get a can of carb cleaner and spray it at the base of the carb, if the RPM's pick up you have a leak. If its not the carb to the intake one of your vac hoses is cracked or leaking i would think.
71Mach14spd is offline
Old 04-11-2010, 06:38 PM
Gun Jam
Moderator
Gun Jam's Avatar
and does the whistle get louder or change pitch when RPMs increase or decrease?
Gun Jam is offline
Gary Ugarek
09-05-2015 09:03 PM
HorsePower99
08-26-2015 11:29 PM
HorsePower99
08-26-2015 08:32 PM
Hogquad
08-23-2015 05:26 AM
daytooday
08-16-2015 08:22 AM
Quick Reply: Whistle coming from motor
