Bulletproof Cooling Recommendations
Old 05-25-2010, 06:07 PM
OCHOHILL
OCHOHILL's Avatar
Originally Posted by Iskwezm
My buddy has a stock 3 core radiator with a Spal 16" fan it cools his 347 to about 185-190 on a 90+* day.Usually it runs at about 175-180*
I went with a 28X19 Nothern,Taurus fan and Meizere 55GPM pump.
28x19??? Isn't the bottom 3" behind the front crossmember. I suppose if the fan is pulling there it helps.
I ran a 28x16 norther radiator. You have to cut up the radiator support to move it forward and to open up the hole. The Taurus fan fits nicely if you move the engine back an inch or so. You can also run a mechanical fan without moving the engine back.
Be prepared, bulletproof cooling means modifying stock.
OCHOHILL is offline
Old 05-25-2010, 11:52 PM
68EFIvert
68EFIvert's Avatar
I used a custom radiator from wizardcooling.com. It is beautiful and works as good as it looks. He hooked me up with 4 9" fans. 2 come on at 180 and the other two at 195. I am also running a Meziere 55 gph electric water pump. The car actually runs cooler while sitting in traffic than while cruizing. I am running a blower on my car now. The radiator is going to run you a bit more than a griffin and a single electric fan but worth it IMO.
Make sure you are very cautious of the fan depth if you plan on running a blower. I only have about 2" of clearance between the crank pulley and the radiator. That made me have to go with a dual fan setup or what Scott at wizardcooling.com suggested, 4 fans. I ended up going with a dual pass (both inlet and outlet on the same side) so that I had clearance for the upper radiator hose. Depending on the type of blower you may use you may need to do the same. Here are a couple pictures.
http://wizardcooling.com/
68EFIvert is offline
Old 05-26-2010, 07:25 AM
ozarks06
ozarks06's Avatar
68EFIvert, that fan setup is a thing of beauty, as is the whole car!
ozarks06 is offline
Old 05-27-2010, 01:49 AM
Aussie66Fastback
Aussie66Fastback's Avatar
i had a little party in my shorts when i saw that engine bay, 68efivert.
that is automotive **** right there
Aussie66Fastback is offline
Old 09-29-2011, 06:24 PM
robv
robv's Avatar
Originally Posted by ozarks06
I have a 24 X 19 Griffin radiator with a 95 Taurus 3.8L fan. It cools extremely well - never gets above about 195, even in the hottest weather in creeping Branson, MO traffic. It's cheap too - $200 for the radiator and $35 for the fan (and $95 for a new fan motor after the junkyard motor died).
where did you find the radiator for $200? everywhere i look they are $400+
robv is offline
Old 09-29-2011, 08:02 PM
ozarks06
ozarks06's Avatar
If I remember right, this is it:
http://www.summitracing.com/parts/GRI-1-26202-X/
ozarks06 is offline
BOB ROME
07-26-2023 01:54 PM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: Bulletproof Cooling Recommendations
