What to paint what on a completely new under body
Ok, now when you guys say paint it black, you mean everything? Technically weren't somethings left unpainted.
As far as the under coating, how does it compare to the regular painting of black? Would you say it looks unoriginal? This will definitely be the last time I redo this car so maybe the undercoating would be best, I just worry it might look or standout as after market.
John
John
I got tired of going back and forth in my mind so out of the blue I ordered some Duplicolor bed coating. Not the newer kevlar stuff, but the cheapy. I fought with a spray setup until I got it to spray and the results are way better than I'd hoped for. It's all black - everything (satin) and looks great! Anybody picky enough to look under it and say something to me about it not "looking factory" had better be outta foot range. This bed coating won't take the abuse of real bedliner, but it really does a good job of "losing" the seams from patch panels and such plus if there's a need to get a bolt out, it won't be as bad as doing so with bedliner.
Good color
Good hiding
Nice subtle texture.
If you can't spray it (not the easiest to do), there is a roller kit available as well.
Good color
Good hiding
I would use satin or flat black and paint it. I will never use any type of undercoating on anything I own. If it chips off it will hold in moisture. I also vote no for bedliner. If you ever need to remove it, it will be nearly impossible. I have also seen numerous bedliners flake and chip etc.
There are a few things like the transmission, shocks, gas tank, and fuel/brake lines that I would not paint if possible.
Good color
Good hiding
Good color
Good hiding
Hello,
I am in the middle of restoring my 68 Stang convertible.
With new floors and much more new structural things the time has come to start repainting the new bottom of the car which is mostly bare much.
So my question is, what areas should be painted and what colors should these areas be, trying to be as original as possible.
Thanks for you help,
John
John
There is no color code for the primer used under the car. The factory just used what they had on hand and often would mix 2 or 3 lots of primer together when they were getting empty to stretch it out for more cars. There is a wide variety of colors out there and none are considered incorrect. I would use a red oxide and call it a day. Also the factory didn't mask off the car as different areas were painted, so there was a lot of overspray underneath. The body color just kind of fades as you move from the rockers to the tunnel on the floor pans and the engine bay black does the same from the front towards the back. Everything was bolted on after the body was painted so things like the steering linkage, tie rods, etc are all natural, the control arms were dipped into black paint, but the ends where the ball joints are were left unpainted. engines were painted after they were assembled and transmissions were unpainted. Many of the brakets, like bumper and engine accessories were painted off the car and added later as well. Hope that gets you started.
