Power steering
Old 06-15-2010, 07:13 PM
ColtonS3290
ColtonS3290's Avatar
Default Power steering
Hello,
I have a 1969 351w in my 1971 coupe and it does not have power steering, and id like to put it on, i am going to the junk yard and getting a used one here soon but not to sure on what all i need to tear out to make it work to well, any help?
ColtonS3290 is offline
Old 06-15-2010, 08:24 PM
2+2GT
2+2GT's Avatar
For the 71 part you'll need the hoses, hose bracket, and steering gearbox. For the engine you'll need the pump, pump brackets, bracket adapters, and pullies. You'll want to be sure you use the 69 351W 3-bolt crank pulley and harmonic damper. The 69 offset will not line up with any of the later stuff, so don't even try to mix and match. The 69 stuff is available new, so if you can't find it you'll be OK.
2+2GT is offline
Old 06-16-2010, 07:00 AM
chockostang
chockostang's Avatar
The 69 Cradle bracket will be made of aluminum (C7AA). If you acquire a Cradle bracket that is made of steel, it won't work. Pump pulley has to be a straight up (7AA/AF/Etc), Steel support HAS TO BE 67-69 Small block. Pump can be BG/BF/BK style thompson-TRW.
Dan @ Chockostang
chockostang is offline
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
09-25-2015 06:58 PM
Quick Reply: Power steering
