Drip rail weatherstripping?
For the Drip rail weatherstripping, Up under the door frame/top of window glass. The new rubber weather strip has a metal end with a screw-hole in the front. It is for a 65-66 coupe. My original weatherstrip did not have the screw mount. It had a little tab that dug into the rubber. I think this was specific for the 64 and early 65.. So the new weatherstrip does fit, but this metal tab just hangs loose and will come off with use. So do I tap a hole into the door frame to mount it like it should be (That is how the original metal trim that holds the weather strip is attached all around the door frame.)?
Thanks again!
foxtrot
09-29-2015 06:32 AM
09-17-2015 07:57 PM
zanemoseley
09-06-2015 12:58 PM
